Hi
Just re installing the re manufactured wiring harness to the mk1 cooper S. I can see from the wiring diagram that the motor must have been changed for a later type. The one I have has the square body and 2 spade terminals. One marked and the other two plus a earth terminal on the body of the unit that has a wire earthing to the chassis.
My wiring harness has 3 wires available at the motor end
Black/green stripe
Red/green stripe
Green
obviously 3 into 2 doesn't go?
Also at my switch I have only a Black/green connected and a green to the other side of the switch.
I need to know what color to terminal 1 and terminal 2 please
Hope someone can help
Regards
Brad
wiring question - Lucas Wiper motor
- Number Six
Re: wiring question - Lucas Wiper motor
Hi,
Perhaps you can figure out by these diagrams to sort things out.
http://www.advanceautowire.com/mgb.pdf
Its also handy for tacho’s and alternators etc. it goes from simple to complicated.
André
André
Moke My Day
Thanks thats very helpful. blk/green terminal 1 and grn terminal 2
Thanks again for the input.
