engine/gearbox weight?
Posted: Sun Jul 15, 2012 10:04 am
by YMJ
Hi,
Any of you geeks out there know how much an engine/gearbox unit with carbs weighs to the nearest Kg or lb?
Re: engine/gearbox weight?
Posted: Sun Jul 15, 2012 11:37 am
by EAVB
I've got the weight of an engine & box with starter and alternator written down as 159kg.
I can't remember exactly what the spec of the one I weighed was but I'm guessing 1275, remote change box if that helps.
I know I can only just pick one up by myself to put in the van. I found this out last week when collecting an Ebay purchase from somebody's grandmother!
Posted: Sun Jul 15, 2012 12:48 pm
by YMJ
The fact that you can lift 159Kg is impressive enough. That you can lift that mass when presented in the form of an engine/gearbox combination, all the more so.
Posted: Sun Jul 15, 2012 5:11 pm
by cheleker
Getting to the "nearest Kg or lb" would require a lot of very specific information about engine size (1275s weigh more than 850s, for example), build specification, what accessories and even which/how many carbs. Getting close enough for practical uses, the 159kg quoted is pretty close and biased maybe on the high end. I normally use 150kg/330lbs as a good average.
Posted: Thu Jul 19, 2012 12:12 pm
by YMJ
Thanks, that's all good stuff.
