engine/gearbox weight?
YMJ
Post by YMJ »
Hi,
Any of you geeks out there know how much an engine/gearbox unit with carbs weighs to the nearest Kg or lb?
Thanks :ugeek:
EAVB
Has thanked: 4 times
Re: engine/gearbox weight?
Post by EAVB »
I've got the weight of an engine & box with starter and alternator written down as 159kg.
I can't remember exactly what the spec of the one I weighed was but I'm guessing 1275, remote change box if that helps.
I know I can only just pick one up by myself to put in the van. I found this out last week when collecting an Ebay purchase from somebody's grandmother!
Probably surfing.
Cornwall, UK.
YMJ
Post by YMJ »
The fact that you can lift 159Kg is impressive enough. That you can lift that mass when presented in the form of an engine/gearbox combination, all the more so.
cheleker
Post by cheleker »
Getting to the "nearest Kg or lb" would require a lot of very specific information about engine size (1275s weigh more than 850s, for example), build specification, what accessories and even which/how many carbs. Getting close enough for practical uses, the 159kg quoted is pretty close and biased maybe on the high end. I normally use 150kg/330lbs as a good average.
YMJ
Post by YMJ »
Thanks, that's all good stuff.
