Key numbers
- Has thanked: 7 times
- Been thanked: 6 times
Key numbers
Does anybody know where I find the key number on the ignition barrel of a Mk 1 or Mk 2 Mini. I can see some numbers on the side but they look like date of manufacture to me. Cheers. Mark
- Frogeye61
- Simon776
Re: Key numbers
Indeed it should but that won't be stamped on the barrel only the three digit number.Should start with FP, FS or something like that
Re: Key numbers
Still can't find it. I took the cylinder out of the housing. All I can see is several numbers on the ignition barrel housing ie the one with electrical connectors on it. Any chance of some pics showing where to look. Is it the barrel with tumblers part or the barrel housing with the spade terminals? Cheers. Mark
Re: Key numbers
Thanks guys. Found it. Removed the barrel, the number was smothered in graphite grease but eventually found it just lurking behind the chrome front collar.
