Tuning the 850 engine?
Chalkie
Post by Chalkie »
Hey guys
since my 1000 blown up :( I got given a 850 engine but 35 bhp isn't quite enough in my eyes
since i ride a quad with 55 odd and all my mates have 1275 minis
anyone got any ideas :)
thanks Stephen
contour51
Re: Tuning the 850 engine?
Post by contour51 »
RidingLow wrote:Hey guys
thanks Stephen
IMO
There are soooo many "tweaks" and different opinions/ideas.I suggest get 'Tuning 'A' series engines ' by David Vizard or 'Mini Tuning ' by Clive Trickey and read up.Then you can do do what your budget runs to.
G.
e-type
Post by e-type »
I had a nice 850 engine 15 years ago.
spec. was:
head 2mm off to raise comp. ratio
stronger springs from std 1275.
alloy inlet with gas flowed 1.5" S.U. and tweeked needle
LCB with RC40
homemade alloy flywheel (same weight as ultra light steel flywheel)
won some auto testing events with that one even against 1275cc minis
maybe it only had 45 bhp, but it was realy quick in 1 and 2nd gear
Follow my 850 speedwell project for some more tuning tricks :P
Thomas
Chalkie
Post by Chalkie »
e-type wrote:I had a nice 850 engine 15 years ago.
spec. was:
LCB with RC40
Thomas
Got a link please :)
I love small bore engines always more fun!
I'm going to build an engine up for my next mini a 1310 16v but for this one i want a quick small bore
and i have Vizards book :) i haven't read it yet :(
Tim
Has thanked: 4 times
Been thanked: 17 times
Post by Tim »
If you really want a quick small bore, why not start with a 998 or 1098? The 998s should still be very common over there (they're not that hard to get here) and they have a stronger crank, proper bearings on the camshaft etc. There's no substitute for cubic inches.
Its perfectly possible to build a warmed 850, I'm actually building a lightly modified one myself, but that's entirely for the sake of originality. I'd be going for an 1100 if I was trying to get more power on a budget.
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Chalkie
Post by Chalkie »
I have a 998 engine but needs an over bore what I can't afford at the moment
Just wanted the 850 to be a little bit quicker
My old boss said his mate use to have a "Hot Rod" 850 it use to sit and rev at 1500rpm idling use proper scream along the street
also my 850 have cam bearings :)
Tim
Post by Tim »
Its entirely your call. All I'm suggesting is that you do your sums before you start. By the time you do a cam swap, some work on the head, a set of extractors and a bigger carb, your free engine won't be looking so cheap.
Tim
1955 BSA C11G
1969 Triumph TR6R
Chalkie
Post by Chalkie »
is a 998 cam better than a 850? cause i have one
I have hs4 gas flowed carb sat in the shed
and i can polish all the ports
think that will do to be fair then ill build one when i have more money
Tim
Post by Tim »
RidingLow wrote:is a 998 cam better than a 850? cause i have one
Actually, I don't know enough to say, but would guess 'not much', I'd have to look up Vizard to see what he reckons. From memory there are incompatibilities with oil pump drives or something.
RidingLow wrote:I have hs4 gas flowed carb sat in the shed
Probably a good start, you'll want to be sure not to over carb it. That will depend on how much work has been done on gas flowing it. and What you do with the head and inlet manifold Do you have a matching inlet manifold for it? The 850 one suits an HS2 and is a bit small. A later 998 one to suit an HS4 is needed.
RidingLow wrote:and i can polish all the ports
On its own, that probably won't help enough to be worthwhile. You really need to reshape the combustion chambers to open them up. The 850 head is the worst for 'shrouding' of the valves, and they have the smallest valves. you could put a lot of work into an 850 head for not a lot of reward. If you can track down a 12G202 cylinder head that was used on the 1100, it would be a better starting point for modifications, unless you can find a 12G295 or 206 head and get the compression ratio up.
RidingLow wrote:think that will do to be fair then ill build one when i have more money
Yeah, they are all on the right track, but be prepared to find that you haven't gained a huge amount. I've kind of reached the limit if my experience with 850s now though, so I'll shut up. Hopefully someone who has done it before can fill you in on what will give you the biggest gains most cheaply. Also the yellow Vizard bible is a great background reference when you are starting out, and so cheap now. http://www.amazon.co.uk/Tuning-A-Series ... pd_sim_b_1
Tim
1955 BSA C11G
1969 Triumph TR6R
Chalkie
Post by Chalkie »
Okay thanks for all that information
you know what Ill change the gear box to rod change as my cars rod change
and leave it!
thanks so much
Stephen
