Weber 40DCOE
WNX700H
Weber 40DCOE
Post by WNX700H »
Is there any significant difference between the new weber 40DCOE that is on the market compared to those of sixties / seventies era?
Need to buy a pair for my 8 port .
Smiffy
Re: Weber 40DCOE
Post by Smiffy »
The main difference between the newer versions and the old ones, are the venturi balance screws. These allow air to bypass the throttle plate and make getting a decent/steady idle a lot easier. With the older carbs you needed to drill a small hole in the bottom of the throttle plate, starting with a small hole and then enlarging it until you got a decent idle. If your weber has a white cap, just above the throttle spindle it's the newer version.
WNX700H
Re: Twin Weber 40DCOE for 8 port
Post by WNX700H »
Does anyone know know who does a kit for the Arden eight port engine?
Astro
Re: Weber 40DCOE
Post by Astro »
Hi,
there will be no single solution. This depends on the engine and on the chassis (GT or just mini). It is not just a bold on affair, especially if it is a common mini you will need to change the engines position, the bonnet and more.
