helical transfer gear noise
KA2S4
Post by KA2S4 »
Hi Guys,
The transfer gears on my 970 have started to whine,
I rebuilt the motor 1500 miles ago and the transfer gears were silent, but now they have started to make a noise similar to a S/C box.
I can hear them with the box in neutral and the clutch out, when the clutch is pushed in the noise goes away.
Will it get worse? should i be concerned?
James.
Chalkie
Re: helical transfer gear noise
Post by Chalkie »
Sounds like a bearing to me. Did you replace them in the Transfure case?
bmcman.ie
Post by bmcman.ie »
james, unfortunately, i think its an engine out jobby whichever way you look at it, damage limitation is the order of the day, :cry: ian.
Gray
Post by Gray »
Thats the bearings for sure James, mine did that on my 1275 engine before it let go, gearbox, transfer case and tranfer gears were all trashed so don't chance it, join the engine out club James :( :x
66S
Post by 66S »
James, I agree with what others said re checking it without delay. If a noise is getting noticably worse, something is wrong and it must be checked to avoiud catastrophic failure. Prob'ly not what you wanted to hear :(
Al
970s
Post by 970s »
:idea: James,
You should fit a SC set this time when your engine is out!
So you won't hear a strange noise but just the normal SC whine! :mrgreen:
Your 970s motor is stunning!
Al
