CSI-Ignition Electronic Distributors
Has thanked: 253 times
Been thanked: 223 times
Useful report's in recent MCR CooperWorld Magazine's here:
http://www.csi-ignition.nl/bestanden/co ... 12_csi.pdf
http://www.csi-ignition.nl/bestanden/cooper_world.pdf
http://www.csi-ignition.nl/en/technical_info.html
CSI-ignition is a fully electronic ignition built in an original looking Lucas, Bosch or Ducellier housing. You will have to remove the cap to see the difference!
It is a direct replacement for the standard Distributor.
The CSI-ignition is easy to install and will bring you a lot of advantages. Your car will have more torque, better emission, a smoother run and start, less fuel consumption and the ignition is maintenance free. After removing the cap you can select between 16 different curves by using a screwdriver. A bright flashing led light shows which curve you have selected.
The Swiftune CSI Distributor has our own bespoke curves developed using our 45+ years of A-Series engine tuning that cannot be purchased anywhere else. The 1 dizzy suites everything from a standard 850 Mini upto full-house 1460cc Racers! Just simply a choice of 16 curves built into the 1 unit…Simple!
The CSI-ignitions are tested in the classic rally sport. Cars with our ignition competed in long distance rallies like the Carrera Copacabana, Monte-Carlo Historique, the Wintertrail, Amsterdam-Beijing and the Tulpen Rallye.
Each distributor is complete with Rotor Arm and Cap.
http://www.swiftune.com/Product/1090/sw ... a-59d.aspx
