scott6058
Posts: 340 Joined: Wed Aug 04, 2010 7:40 pm
Has thanked: 2 times
Post
by scott6058 » Sat Apr 07, 2012 5:29 pm
I thought I could ask a favor. I'm looking for a good mild street cam for my resto.
HS2 and stock header and muffler. I might try an LCB if anyone thinks it would be a good idea.
Smooth idle I would enjoy and low torque as I would like to have a 2.95 final drive or is this to tall for a 1071?
Thanks for anyone's input.
Scott
SMOKE GREY
Posts: 1561 Joined: Thu Jun 24, 2010 7:31 pm
Been thanked: 10 times
Post
by SMOKE GREY » Sat Apr 07, 2012 7:00 pm
Cam wise , one answer Swiftune SW5-07
Diff 3.2 is probably the tallest i'd go far, depends what sort of roads are local to you.
scott6058
Post
by scott6058 » Sat Apr 07, 2012 7:38 pm
Thanks Smoke Gray
We have a wide variety of roads around here. I really was considering a MG Metro Vanden Plas cam but it's getting hard to find. I'll take a look at swiftunes sw. Thanks again
Scott
In the shed
Posts: 669 Joined: Mon Aug 16, 2010 3:10 pm
Post
by In the shed » Sat Apr 07, 2012 9:14 pm
You sound like you are after a 1275 engine really. Put a 286 in the 1071 and run it through a 3.7.
scott6058
Post
by scott6058 » Sat Apr 07, 2012 10:34 pm
In the shed wrote: You sound like you are after a 1275 engine really. Put a 286 in the 1071 and run it through a 3.7.
Yes I am probably wrong with the final drive
Smiffy
Posts: 707 Joined: Fri Jun 25, 2010 10:33 am
Been thanked: 4 times
Post
by Smiffy » Sat Apr 07, 2012 10:41 pm
Kent cams 500 is the MG metro cam, if you want a new one.
scott6058
Post
by scott6058 » Sat Apr 07, 2012 10:49 pm
Smiffy wrote: Kent cams 500 is the MG metro cam, if you want a new one.
Smiffy I believe this to be true
I'm having a difficult time finding a Kent 500.
Maybe some luck will come soon.
scott6058
Post
by scott6058 » Sun Apr 08, 2012 12:47 am
Not in stock
Smiffy
Post
by Smiffy » Sun Apr 08, 2012 3:33 am
Surely worth a email just to check
ivor badger
Posts: 365 Joined: Mon Jul 05, 2010 5:45 pm
Post
by ivor badger » Sun Apr 08, 2012 12:57 pm
Twin HS2s mean it's top end strangled, so the 997 Cooper cam or equivalent is just fine. a 3.44 is no problem, afterall I used to tow with mine with a 3.44 diff.
