Identify a S blocks age?
mniwagn
Post by mniwagn »
okay without the proper tag is there a way to identify the age of a 1275 aeg312 thin flange block? I know on Lotus/ford blocks there is a date stamp, is there anything on bmc motors? thanks
Vegard
Re: Identify a S blocks age?
Post by Vegard »
Easy, just post a picture of the main caps, then wait for Simon to see this post :-)
mniwagn
Post by mniwagn »
I can make out 4872 on the center main cap. Has strange raised letters behind where the gen/alt and next to the dip stick oil hole. Different as it a much more crude cast compared to my other 1275 S block.
mniwagn
Post by mniwagn »
and my other block is 12321 thanks
251 ENG
Post by 251 ENG »
What are the ID codes stamped on the caps and the block ?
Should be on the block buy the waterpump or the flat area on the back where the petrol pump is on a non cooper s block
mniwagn
Post by mniwagn »
like C1M5?
251 ENG
Post by 251 ENG »
No , it will probably be a number starting with P or 1P
mniwagn
Post by mniwagn »
1p 4872, 1p 12321
