timing chain
61austinseven
timing chain
Post by 61austinseven »
help iam rebuilding a 850 engine .
i got a duplex timing chain witch i have fitted,
when i do up the crank bolt up it locks the crank up .
is this due to the duplex cogs being wider then a single chain.
the engine is a 1961,any help would be great
Simon776
Re: timing chain
Post by Simon776 »
The two nuts by the bottom sprocket need replacing with countersunk screws.
InimiaD
Re: timing chain
Post by InimiaD »
Here's a pic which substantiates what Simon has said.
Borrowed from DVs book. ;)
814CWE
Re: timing chain
Post by 814CWE »
a good quality kit should usually have the countersunk set screws with it,,, :o
