Fitting Seat Covers (request)
Posted: Sun Feb 19, 2012 7:42 am
by SteveG
I am doing my 59 mini and 62 Cooper.
My Cooper came with covers someone else has done (quite well but not original) My 59 came with seats but not covers so I cant see how they were fitted.
I have complete newtons kits for both but want to put them on right. Has anyone got some photos while they were fitting theres?
The rear ones are ofcoarse simple its more the front base and squab with the little flaps that push into the bottom / rear area.
Cheers for any help.
Steve
Re: Fitting Seat Covers (request)
Posted: Tue Mar 13, 2012 12:09 am
by formulaphoto
Posted: Sat Apr 14, 2012 1:25 am
by SteveG
Thanks Warwick
Posted: Thu May 17, 2012 9:02 am
by Stefan
Here are some pics of my 59 Morris seats:
First fixing the straps
for better fixing use the foil delivered with your seat covers.
The smaller blue foam has to be stuffed into the seat cover first before you fix the cover on the seat frame
Done.
Posted: Thu May 17, 2012 10:16 am
by SteveG
Nice work Stefan.
Posted: Thu May 17, 2012 10:32 am
by Stefan
Thanks Steve.
Posted: Mon May 27, 2013 5:00 pm
by Ratkiller
Is there anything you guys would have done different to add more support to the seats, like adding more foam or doubling the springs?
Posted: Wed Jun 19, 2013 7:06 pm
by Stefan
No, I used the stuff delivered by Newton and it works very well. No extra springs or foam needed even the Newton stuff is different to the original latex Vitafoam. I can only hope it will last as long as the vitafoam did.......
Posted: Tue Jul 16, 2013 5:33 pm
by Ratkiller
My order finally arrived!!!!!!!!!!!!!!!!!!!!
Hopefully the install is as easy as you guys discribe.
Posted: Tue Aug 06, 2013 9:25 am
by KA2S4
Stefan; where did you get that cream strapping from? I think it's called Pirelli webbing...
Posted: Fri Aug 09, 2013 8:44 pm
by Ratkiller
I GOOGLE'd "Pirelli webbing straps", and a ton of suppliers came up.
Posted: Tue Aug 13, 2013 7:34 pm
by Stefan
Sorry for being late with my answer.....
The straps are from Newton. They are seperately available asfar as I know and are cut in the right lengths.
Posted: Tue Aug 13, 2013 11:13 pm
by Ratkiller
Is there a special purpose for going this the strasps over the new metal spring diaphram?
Posted: Tue Aug 13, 2013 11:33 pm
by ricardo
Yes, early seat frames.
Posted: Tue Aug 13, 2013 11:59 pm
by Ratkiller
The reason way I ask, is because my 62" MK1 Morris Mini Minor seats had the straps, but when recovering I put the spring type diaphram, which fit in the same holes along the sides.
The diaphram has more tension, so you sit more upright, it's very springy and comfortable. The straps had less tension and hardly any spring/strech, so you sit back more into the seat.
I actually wish I kept the old straps on, so I can take advantage of the sides of the seats holding me in, when going around sharp corners. But every body I talk to says give it time the springs will loose some tension.
