Front subframe tower top spacers
AndyB72
Post by AndyB72 »
Should my car have the thick spacers between the subframe and the body, I can't remember if it had any when I dropped the frame several years ago. It's a '68 on hydro. Did all the early cars have them?
Simon776
Re: Front subframe tower top spacers
Post by Simon776 »
Only if the Italians did them differently - UK hydro cars don't have spacers.
Steve A
Post by Steve A »
This has me worried :shock: My car is a 66 reg (late 65) car which was on hydro. When it was stripped i don't remember if there were spacers or not but when i fitted dry frames to it we fitted spacers? Have i dropped a bo--ock?
970s
Post by 970s »
No thick spacers for UK or Aussie wet Mini! but watch out if you use new bolts! long new bolts(wet bolt has smaller dia. 3/8') for dry subframe has 5/16" dia, and IT bottoms out when fully screw-in, check the tower and test fit before put back the subframe, it waste me 2-3 hours to re-drop the frame and shorten the new bolts! :evil:
Vegard
Post by Vegard »
Smiffy
Post by Smiffy »
I always thought Hydro cars, ran studs and only the dry ones used bolts.
guru_1071
Post by guru_1071 »
Smiffy wrote:I always thought Hydro cars, ran studs and only the dry ones used bolts.
early dry ran the studs, then went onto bolts
hydro ran bolts (which are different thread to the dry ones (just to confuse people!))
970s
Post by 970s »
:roll: :? :P
I think the studs are much more user friendly! SO easy to align the subframe and crossmember,:mrgreen:
:?: Why change to bolts???
Like the cylinder head studs and bolts?
Al
Simon776
Post by Simon776 »
The general rule is:
Studs = Cowley built
Bolts = Longbridge
Steve A
Post by Steve A »
Hi, so if fitting dry frames to a hydro car spacers or no spacers?
wolseley 1000
Post by wolseley 1000 »
my S.A. Traveller 1000 from 1967 had studs and is a dry car...
I think they just used what was available / in the shelf :lol:
InimiaD
Post by InimiaD »
Another intrigueing thread guys. :?:
I thought (and read) that all Minis up to 1972 had the metal pads / spacers fitted.
I scrapped a 72 and that had spacers. My 68 wet S had spacers and My 67 Woody.
When I get a chance I'll check My 61 and my Wet 68 and another 67 Woody.
As an aside all coopers and S's had bolts rather than studs as tower fixings.
There are 2 types of spacers as well, solid steel and metallistic type with rubber in between 2 steel plates.
Let the debate continue. :P
970s
Post by 970s »
IT is supposed the wet subframe is taller than the dry one, than they don't need the spacers, but when I measure the wet frame it reads 365 mm, the Factory manual gives about 375 mm- :?: that means some how my wet frame is shorter?? But stick to the rule of the game, I have not use the spacers, all seems OK, so if using dryframe (shorter height) on a hydro shell, you need the spacers and you will find the two protruding holes on the towers fits nicely in the spacers plates! Dose it help? Steve!
Why this thing is so confusing?
:ugeek:
AL
Toby
Has thanked: 12 times
Post by Toby »
Does anybody have a change point for the spacers? As there are two types :
T.
InimiaD
Post by InimiaD »
I can't find any change point date at the moment. The 72 I stripped had the solid steel spacers, the type on the left, above.
Managed to get a look at the other Woody (67) this evening and that has spacers fitted.
Smiffy
Post by Smiffy »
My '70 Mk3 has the ones on the right
InimiaD
Post by InimiaD »
My 61 Minor has spacers and the 68 Austin has none. :?
Steve A
Post by Steve A »
Cheers Al, wasn't aware the dry frame was shorter, glad i fitted the spacers.
970s
Post by 970s »
;) Steve,
U are welcome!
:D
Al
monkeyjim
Post by monkeyjim »
I have a 1960 Austin and it has no studs and the spacers on the right .
I must admit it was in bits for 10 or so years after stripping it and has been back on road since 2004 (with new subrame) ......
However because it was in bits so long I had mislaid stuff (as you do) and only remembered the plates when talking to a friend about them coincided with me finding a bag of parts I had forgotten about over several house moves that I had originally wrapped up during dismantling back in 1992 !
So, I run dry without them .
What does that mean ?
Its lowered before I start lower the suspension ? :)
Had no issues fitting frame .
