Oil pressure
Posted: Sat Sep 21, 2024 8:08 pm
by rnp68
Any tips on how to get oil pressure on an engine that has sat for 20 years. None on cranking for 5 minutes. Sorry should have posted in technical.
Re: Oil pressure
Posted: Sat Sep 21, 2024 8:38 pm
by kit of bits
Oil pressure relief valve stuck?
May be a silly question but the pipe or gauge isn’t at fault?
Re: Oil pressure
Posted: Sat Sep 21, 2024 8:46 pm
by rnp68
Guage and pipe removed, no oil out of block. Will pull relief valve out tomorrow and clean.
Re: Oil pressure
Posted: Sat Sep 21, 2024 8:53 pm
by gs.davies
Remove the oil transfer pipe and back fill the pump through the oil transfer pipe hole.
Re: Oil pressure
Posted: Sat Sep 21, 2024 9:04 pm
by rnp68
Will try that also and report back, cheers
Re: Oil pressure
Posted: Sat Sep 21, 2024 9:42 pm
by kit of bits
Just to clarify, it’s sat for 20 years. Was it a runner or a rebuild that wasn’t used?
Re: Oil pressure
Posted: Sun Sep 22, 2024 8:13 am
by rnp68
It was a good runner.
Re: Oil pressure
Posted: Sun Sep 22, 2024 9:12 am
by steve1071
If still struggling, get a pal to back fill it through the oil transfer hole whilst you’re pushing it backwards in gear (with the plugs out of course). Worked for me on motor sat a long time.
Re: Oil pressure
Posted: Mon Sep 23, 2024 9:28 am
by Allen Brzeczek
I agree with an opinion already expressed which has worked for me and something I always do after an engine rebuild, during assembly prime the oil pump by dispensing oil through the block connection for the pipe to the filter. Should then quickly draw up oil from the sump.
Re: Oil pressure
Posted: Mon Sep 23, 2024 12:46 pm
by mab01uk
Useful link below from the Mk1 Forum -
Technical Talk - 'Mini Related How To' section:-
viewtopic.php?t=29329
Direct link with photos of steps taken.
Regaining Oil Pressure After Long-Term "Mini" Storage:-
https://www.7ent.com/pages/article-rega ... orage.html
Re: Oil pressure
Posted: Mon Sep 23, 2024 6:57 pm
by rnp68
Thanks for all the replies, did not get in the garage yesterday, it was a tad wet. On hols now for a week, so will report back when home.
