Oil pressure
rnp68
Oil pressure
Post by rnp68 »
Any tips on how to get oil pressure on an engine that has sat for 20 years. None on cranking for 5 minutes. Sorry should have posted in technical.
kit of bits
Been thanked: 13 times
Re: Oil pressure
Post by kit of bits »
Oil pressure relief valve stuck?
May be a silly question but the pipe or gauge isn’t at fault?
rnp68
Re: Oil pressure
Post by rnp68 »
Guage and pipe removed, no oil out of block. Will pull relief valve out tomorrow and clean.
gs.davies
Has thanked: 42 times
Been thanked: 54 times
Re: Oil pressure
Post by gs.davies »
Remove the oil transfer pipe and back fill the pump through the oil transfer pipe hole.
rnp68
Re: Oil pressure
Post by rnp68 »
Will try that also and report back, cheers
kit of bits
Re: Oil pressure
Just to clarify, it’s sat for 20 years. Was it a runner or a rebuild that wasn’t used?
rnp68
Re: Oil pressure
Post by rnp68 »
It was a good runner.
steve1071
Has thanked: 9 times
Re: Oil pressure
Post by steve1071 »
If still struggling, get a pal to back fill it through the oil transfer hole whilst you’re pushing it backwards in gear (with the plugs out of course). Worked for me on motor sat a long time. :)
Allen Brzeczek
Re: Oil pressure
Post by Allen Brzeczek »
I agree with an opinion already expressed which has worked for me and something I always do after an engine rebuild, during assembly prime the oil pump by dispensing oil through the block connection for the pipe to the filter. Should then quickly draw up oil from the sump.
Has thanked: 191 times
Been thanked: 147 times
Re: Oil pressure
Useful link below from the Mk1 Forum - Technical Talk - 'Mini Related How To' section:-
viewtopic.php?t=29329
Direct link with photos of steps taken.
Regaining Oil Pressure After Long-Term "Mini" Storage:-
https://www.7ent.com/pages/article-rega ... orage.html
rnp68
Re: Oil pressure
Post by rnp68 »
Thanks for all the replies, did not get in the garage yesterday, it was a tad wet. On hols now for a week, so will report back when home.
