What’s this connector called?
gs.davies
Has thanked: 67 times
Been thanked: 64 times
Post by gs.davies »
And where can I get the opposite part?
Has thanked: 231 times
Been thanked: 202 times
Re: What’s this connector called?
I had a very quick look on the three wiring products suppliers listed below but did not notice anything the same...
Vehicle Wiring Products:-
http://mk1-forum.net/viewtopic.php?f=9&t=36264
hanlminiman
Has thanked: 17 times
Been thanked: 32 times
Post by hanlminiman »
Just a thought. As you are using a radio as a background I wonder if one of the old car radio modifiers (adding Bluetooth etc) might be able to help.
If it is not and just a cable connector there are plenty of 2 wire male & female plastic connectors available for auto electric suppliers.
Has thanked: 127 times
Been thanked: 106 times
I've never seen one but it seems to be a complicated version of the simple double ended bullet connector, found almost everywhere on our minis. Just been using plenty of them re-wiring clever Trevors mini!
111Robin
Been thanked: 16 times
Post by 111Robin »
I have one with about a foot of cable attached. PM your address and I'll put it in the post.
Bob46320
Post by Bob46320 »
As 111Robin shows but one pin fatter than the other to polarise the plug/socket.
Bob46320
Post by Bob46320 »
111Robin
Post by 111Robin »
The Radiomobile speaker plugs I've had have all had the same pin diameters, perhaps different types on other radios. The one I have was attached to a Radiomobile.
gs.davies
Post by gs.davies »
111Robin wrote: Tue Jun 04, 2024 4:59 pm I have one with about a foot of cable attached. PM your address and I'll put it in the post.
That’s very kind, I’ll drop you a PM
Gary
Tim
Has thanked: 4 times
Been thanked: 22 times
Post by Tim »
The ones shown look very similar to the old park light accessory sockets, but the pin spacing seems a bit wider, so I suspect confusion is likely.
My Traveller has the socket on the dash. I plan to use it for my phone charger, with a bridge rectifier to ensure correct polarity.
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
