Does anyone have a cutaway section view (photo or drawing) that shows all the internal fluid channels of an Cooper S caliper?
Many thanks!
Ed_
Cutaway Section View Of 7.5" Cooper S Caliper?
- sandman
- Has thanked: 94 times
- Been thanked: 76 times
Re: Cutaway Section View Of 7.5" Cooper S Caliper?
If you are game to separate both halves of the caliper you can see it for yourself
Can I presume that the fluid duct in your caliper is clogged up? With them apart you can slowly rotate the exact size drill bit through the ducts that are visible. I did it with a set that I bought cheap - because the ducts were clogged up by old water contaminated brake fluid. All it cost was a set of caliper seals
- timmy201
- Been thanked: 25 times
The outer half of the caliper is pretty straightforward, I believe a straight line from the port to the piston bore
Bleed nipple
Brake hose
Bridging passage to outer half
Port to piston bore
There is a blanking plug with a copper washer which would allow access for the passages to be drilled and cleaned (which are all straight drillings)
The inner half is a bit more complicated as it joins:Bleed nipple
Brake hose
Port to piston bore
BRILLIANT Tim..... Explains it all.
I was able to clear my spare set within a few minutes. I even annealed and re-used the copper gasket as I recall
