Gear linkage rod bushes?
haynes
Post by haynes »
How do I change the bush on top of the diff housing, for the long rod that comes up from the underneath, connecting with the remote change. Does it tap out easily from the other side? Or do they get stuck, need heat etc? (Gearbox is out the car).
Minispares say theres 2, wheres the second Bush located?
Lakeland997
Re: Gear linkage rod bushes?
Post by Lakeland997 »
There's one at the top and another at the bottom.
They usually tap out quite easily with a long punch or metal rod from the opposite side.
Don't try to tap them back in. They are quite fragile - sintered I think.
Use some threaded rod with nuts and big washers to press them in to place.
Andy
Has thanked: 179 times
Been thanked: 61 times
haynes wrote: Sat Apr 06, 2024 8:51 pm How do I change the bush on top of the diff housing, for the long rod that comes up from the underneath, connecting with the remote change. Does it tap out easily from the other side? Or do they get stuck, need heat etc? (Gearbox is out the car).
Be careful when changing the bush that's in the diff cap - it's easy to break the casting. I made a tool that works on a thread to pull the old one out and press the new one in.
I suspect the bushes you were looking at are those that go in the back of the shifter housing, there is 2 there.
This is the one that goes in the Diff Cap;-
360gts
Been thanked: 51 times
Post by 360gts »
Along with what Chris says....
I tap the bushes...(from memory...think it I use a 7/16 tap)!!!.
Then, thread in a suitable bolt....use a long thin bar and tap them out.
Installing new ones is a different job
I use a long threaded rod with nuts and washers to pull the new bushes into place.
I also soak them in oil overnight prior to installation.
GraemeC
Post by GraemeC »
Obviously some confusion as to which bushes you mean. I think you’re describing these bushes:
In which case Lakeland997’s explanation for fitting is correct.
Has thanked: 131 times
Been thanked: 113 times
Lakeland997 is also dead right regarding the use of lengths of threaded rod and washers to act as a gentle puller when pulling in new bushes. Don't forget that you can use the same plus sockets when pulling the old bushes out.
And, as Dermott says, leave them in oil overnight or for at least 12 hours
Lengths of 10,12 and maybe 14mm lengths of threaded rod are something that home fitters should have in their odds and sods drawer. Available from all the half decent hardware stores such as Sydenhams
haynes
Post by haynes »
Hmmm, no luck at all with this so far. The lip seems so small so I cant punch either of them out, it just slips off. The hole is a little larger (13.2mm) than the largest ie 1/2" tap that I have so cant try the puller method either. Grrrr.
Cant you just machine up a small suitably sized inner and outside dia punch. Simple job using a bit of off-cut.
Won't a shortish length of 10mm threaded rod and nut do it? If you lived near Oxford, we'd have that done before tea - just time for a beer at The Dog House!
GraemeC
Post by GraemeC »
I’m still unsure which bush your looking to remove?
If it’s the gearbox steady bush as Spider describes then there’s a video here (although I’ve not watched it):
https://youtu.be/-rtmUzNQTsI?si=Pzw0-1rOdTgseTDW
I have previously melted the rubber out of those and then collapsed the remaining outer tube from the side.
Peter - not everyone has machining capabilities in their garage!
haynes
Post by haynes »
Hi Graeme C, it's the bushes you linked to, for the rod that goes from the remote change up through the diff housing.
The shaft itself measures 12.5mm so that's 1/2 mm of slop!
Because theres a bush at either end, I cant get anything OD inside there.
bwaminispeed
Post by bwaminispeed »
Re read 360 GTS post, he's got it right (except the tap size).....
Tap the bush 9/16 coarse, thread a 9/16 coarse bolt into the bush, and, use a piece of 1/2 inch round rod to knock the bush out from the other end......
To do the other bush, do the same, or, use a piece of rod just a bit bigger than 1/2 inch to tap the bottom one out......
haynes
Post by haynes »
Tis done!
I dont have a large enough tap but I did have a large bolt. Bush was soft enough to allow it to cut it's own thread. However the puller method didn't seem to be doing anything, so instead it was easy to tap it out with bar hitting through from the other end, now in contact with the bolt, now wedged inside the Bbush.. 2nd one was easy.
