Floor Start Exhaust?
Posted: Wed Nov 23, 2011 7:05 pm
by mab01uk
Does anyone still sell the floor start style exhaust as pictured below? The later exhaust passes very close to the switch terminals!
Scroll down:
http://www.1959miniregister.com/the-195 ... l-changes/
These two pictures show the difference between a standard single box system on the left and a system for a floor start Mk1.
Re: Floor Start Exhaust?
Posted: Thu Nov 24, 2011 11:21 am
by 814CWE
i still have a couple of new van/estate floor start type exhausts
could u modify these to fit a saloon? or weld the front half into a modern system?
in all fairness,,i just warm em up and bend to give necessary clearance
Posted: Thu Nov 24, 2011 11:23 am
by 814CWE
correct me if im wrong,,but the pinched/crimped silencers were only available as a budget aftermarket system anyway,werent they?
Posted: Thu Nov 24, 2011 3:31 pm
by mab01uk
The exhaust in question is for my brothers early Traveller, see below:
http://www.minitravellerandcountrymanre ... &Itemid=17
He has fitted exhaust but it is very close to starter button terminals.........will see if he can heat and bend pipe as you suggested if he thinks it is a problem. He also has a 1960 Austin 7 with same issue but never realised/remembered there was a subtle difference in early exhaust shape.
I think I may have had crimped boxes from BL in later years but not 100% sure now.
Posted: Thu Nov 24, 2011 3:44 pm
by guru_1071
im sure i have a nos unipart early exhaust system that has the crimped box.
will have a rummage
Posted: Thu Nov 24, 2011 5:31 pm
by Andrew1967
We have recently fitted a NOS Unipart crimped, single box, system to our Mk2 998.
I cut down a floor start van exhaust for my 1960 850 and have another NOS one as a spare, should I ever need it.
