Floor Start Exhaust?
Has thanked: 253 times
Been thanked: 223 times
Does anyone still sell the floor start style exhaust as pictured below? The later exhaust passes very close to the switch terminals!
Scroll down:
http://www.1959miniregister.com/the-195 ... l-changes/
These two pictures show the difference between a standard single box system on the left and a system for a floor start Mk1.
814CWE
Re: Floor Start Exhaust?
Post by 814CWE »
i still have a couple of new van/estate floor start type exhausts
could u modify these to fit a saloon? or weld the front half into a modern system?
in all fairness,,i just warm em up and bend to give necessary clearance
814CWE
Post by 814CWE »
correct me if im wrong,,but the pinched/crimped silencers were only available as a budget aftermarket system anyway,werent they?
The exhaust in question is for my brothers early Traveller, see below:
http://www.minitravellerandcountrymanre ... &Itemid=17
He has fitted exhaust but it is very close to starter button terminals.........will see if he can heat and bend pipe as you suggested if he thinks it is a problem. He also has a 1960 Austin 7 with same issue but never realised/remembered there was a subtle difference in early exhaust shape.
I think I may have had crimped boxes from BL in later years but not 100% sure now.
guru_1071
Post by guru_1071 »
im sure i have a nos unipart early exhaust system that has the crimped box.
will have a rummage
We have recently fitted a NOS Unipart crimped, single box, system to our Mk2 998.
I cut down a floor start van exhaust for my 1960 850 and have another NOS one as a spare, should I ever need it.
