Dynamo to Alternator
gs.davies
Has thanked: 70 times
Been thanked: 66 times
Post by gs.davies »
I'm considering an alternator conversion on my car. The loom was new last year and was a dynamo specific loom - I plan to gut an old control box to use as a junction box but I'm wondering if I need to somehow beef up the yellow cable that runs to the dynamo to take the extra current.
Would running a second cable in parallel suffice?
Has thanked: 132 times
Been thanked: 113 times
Re: Dynamo to Alternator
But first, a question for you Gary..... Is your new loom cotton braided or wrapped tape?
If it is tape wrapped, like my 69-S then I wouldn't even bother with a duff/empty control box to act as a junction box. Just unwrap the relevant parts of the loom and join the wires, heat shrink the joints - Then re-wrap. It's invisible
If it's a cotton braided loom, then that's slightly different. But only slightly because you've still got to un-pick it. But this time, you can't hide it as you would a tape-wrapped loom.
My loom was a bit of a pigs ear, with a useless 11AC alternator that wouldn't pull you off the nest and an external regulator. BUT, it was a tape wrapped loom. So I unwrapped it, got some new loom tape (for heavens sake, don't use sticky stuff....) and made a new front loom that incorporated the ACR harnness. All invisible
On the other hand, my pal Dave Chaplin did the same but made a distinctly separate loom for the charging circuit. And then sold the perfect control box!
gs.davies
Post by gs.davies »
It's a cotton wrapped loom as per the original fitment...
If I have to put another cable in, I think I'll get another length of the thick yellow cotton braided stuff and put it in a sleeve and route it along with the existing trunk back to the control box. I suppose I'll also have to run it back to the solenoid under the floor too to ensure that the circuit back to the battery has enough capacity.
I don't fancy unwrapping a relatively new loom
timmy201
Been thanked: 37 times
Post by timmy201 »
I bought an alternator from a local mini auto electrician and he included a new length of thick wire to go from one of the alternator charging terminals (there’s 2 or 3 + terminals) to the starter solenoid
In my case the push button starter solenoid is under the floor, so I added a battery distribution post in the engine bay and connected it to the battery side of the starter switch. I figured at the time it would be handy to have a decent source of high current battery cable to the engine bay in case I wanted to add spotlights/headlight relays and not use the existing wiring
Some photos - normally I had a rubber battery terminal cover over the post to prevent any shorts. I’ve since changed the post for a dummy starter solenoid to make it look a bit neater. You can of course mount the post anywhere in the engine bay, probably down near the subframe would have been better
Now I’m using an Aussie solenoid bracket and dummy solenoid. (One day I’ll get a smaller terminal cover)
gs.davies
Post by gs.davies »
timmy201 wrote: Wed Jan 10, 2024 6:43 pm I bought an alternator from a local mini auto electrician and he included a new length of thick wire to go from one of the alternator charging terminals (there’s 2 or 3 + terminals) to the starter solenoid
Now that IS a great idea! I do plan on adding some lamps up front and I’ve had an idea involving putting heating pads into my seats…
