Metal ring behind cooling fan
panda911
Post by panda911 »
Hello all.
Would anyone be able to tell me exactly what is the purpose of the steel ring behind the 11 blade cooling fan on the 1070 Cooper S
It fits exactly into the back of the fan and then sits on the water pump boss
Four bolts though the fan hold everything together, it almost looks like a shim and is appox 3/16 inch thick.
The four bolts are 1.25 inch long and aparently according to the MS parts list are supposedly 1 inch long.
When unscrewed they dig into the rad core.
Any info would be appreciated.
Thank you
1071 S
Re: Metal ring behind cooling fan
Post by 1071 S »
Later Oz Minis (I've only seen them on Clubman's) have a spacer (like the one you describe) to move the fan closer to the radiator.
I suppose you would use one to alter the fit of the fan within the rad shroud to improve cooling.
Cheers, Ian
Has thanked: 181 times
Been thanked: 64 times
It's just a spacer. Sometimes more than one is fitted. You want to be sure the fan has clearance to the harmonic damper, lower radiator mounts and in some cases, off the head. Ideally, you'd like to get the fan sitting so most of it is in the cowling, with about 1/4" or less poking out on the engine side. You also might want to check too that there's clearance between the fan and the radiator core so you can slip a new fan belt through there, though, with a metal fan and a 3 tube (core) radiator, that shouldn't be an issue.
360gts
Been thanked: 52 times
Post by 360gts »
Edited.
Polarsilver
Has thanked: 37 times
Been thanked: 51 times
Post by Polarsilver »
i only found out when it came to replacing the Fan Belt .. there was not enough clearance between the fan & rad; cowel .. only then realised i had not fitted that Spacer behind the Pulley .. with Spacer fitted .. solved that problem.
Also had the experience of the over long 4x Bolts :roll:
Dearg1275
Post by Dearg1275 »
If you offer up the fan and spacer with the bolts already through there is no clearance issue. A bit of masking tape over the heads to hold them in place while positioning everything helps.
hanlminiman
Has thanked: 18 times
Been thanked: 33 times
Post by hanlminiman »
Polarsilver wrote: Mon Dec 11, 2023 10:24 am i only found out when it came to replacing the Fan Belt .. there was not enough clearance between the fan & rad; cowel .. only then realised i had not fitted that Spacer behind the Pulley .. with Spacer fitted .. solved that problem.
Many years ago when I had an engine rebuilt the engine builder suggested adding an extra inoperative fan belt - just in case it needed to be replaced in a competitive environment against the clock. After 12 years it was still there?
Been thanked: 49 times
hanlminiman wrote: Sun Dec 17, 2023 5:50 pm
Did that all the time on our cars, but like you they were never actually needed ;-)
panda911
Post by panda911 »
Thank you for the posts.
I need to fit shorter bolts although someone did suggest that for a Mk1 64 1071Cooper S, there never was a spacer fitted
in production.
BR
P
