Engine test bed
- Been thanked: 41 times
Engine test bed
Been meaning to build an engine test bed for more years than I can remember. So last week i built this . Once the engines off it I will give it a nice coat of paint . …. Shirley
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Porsche 997 turbo S
I am from Essex
Re: Engine test bed
More images
Porsche 997 turbo S
I am from Essex
Porsche 997 turbo S
I am from Essex
Re: Engine test bed
More images
Porsche 997 turbo S
I am from Essex
Porsche 997 turbo S
I am from Essex
Re: Engine test bed
So the exhaust is connected by a straight pipe going through the garage wall with a silencer on the other side . … Shirley
Porsche 997 turbo S
I am from Essex
Porsche 997 turbo S
I am from Essex
- Ronnie
- Has thanked: 13 times
- Been thanked: 35 times
Re: Engine test bed
Very neat nice to heat your garage
, I think braked castors or jack stands would be advisable.
Re: Engine test bed
Looks like a good start for one of these
- Has thanked: 38 times
- Been thanked: 55 times
Re: Engine test bed
Nice One.. my only concern is will the test bed walk around the garage when the engine is running.
I am envious
I am envious
- Has thanked: 19 times
- Been thanked: 9 times
Re: Engine test bed
I've seen this first hand and its absolutely brilliant. So much nicer to be able to run an engine, set it up and iron out any problems before its in the bay.
Check out that heater assembly and better still the choke and wooden clothes peg
Shirley- If you do plan to take it to Beaulieu next year my only suggestion would be to switch that choke cable for a bakelite one. Looks like a later Mk3 you've used there
PS I always assumed an engine would wander or bounce around if you ran it on the floor. Turns out that when i finally tried it the engine ran like a sewing machine and didn't move at all.
Re: Engine test bed
What a cracking bit of jit. Very well thought out & I am sure it will be very useful.
- Exminiman
- Has thanked: 58 times
- Been thanked: 56 times
Re: Engine test bed
So what wheels are you putting on it, could look good with some Cosmics
Re: Engine test bed
Nice one, my test bed many years ago was driving up the road with no bonnet or grill, oily hand prints all over the paint , exhaust blowing filthy hands on steering wheel . we probably all been there, kens solution is Mature and civilised. Oh I forgot tax in post on windscreen!
- Been thanked: 7 times
Re: Engine test bed
Twin throttle pedals are a nice touch.
You've really put some thought into that - impressive work!
- MiNiKiN
- Has thanked: 93 times
- Been thanked: 31 times
Re: Engine test bed
One throttle pedal for each carb, to controll them individually and as such steer the whole crate
Seriously, brilliant stuff - watched with some envy.
Re: Engine test bed
Thanks for the positive response. Couldn’t wait to try it out and can report all went well . I also wondered if it would move about but it stayed perfectly still . One thing I would do differently is to fit a bigger fuel tank . It ran out after 15 minutes , just enough for the first start up . …. Shirley
Porsche 997 turbo S
I am from Essex
Porsche 997 turbo S
I am from Essex
- Has thanked: 21 times
- Been thanked: 37 times
Re: Engine test bed
A totally stupid question but based on recent experiences and your comment "before installing" - Does the set up identify oil leaks before installation?
