Early windscreen surround
sogatha
Post by sogatha »
I need to repair the usual area on the scuttle and corners of the windscreen surround.
My Mk.1 has the flat edge on the surround and I can only get a later type repair section that has the recess.
Do I need to modify the panel by flattening the recessed edge or if I fit it as it is would the windscreen rubber cover the difference?
Pete
Re: Early windscreen surround
I'm fairly sure it will need flattening out before fitting.
