What is the best carb. on a 998cc engine, there was a Hiff38 on it but it seems not to work propperly in the rives.
I have also a Hiff44 on the shelve, would this do the job aswell ?
Kees
Carb question.
- Has thanked: 135 times
- Been thanked: 113 times
Re: Carb question.
We don't know exactly what 998 engine you have Kees, Was the HIF standard? So it's a difficult one to answer.
I alsays say revert to standard - then work forwards from there
- UHR850
- Been thanked: 9 times
Re: Carb question.
It is a totally overhauled engine and almost standard, thanks for your advice.
Kees
Kees
Re: Carb question.
Hello Kees ,
An HIF38 will work way better in a stock 998 than an HIF44,
Pain points on these carbs are the choke mechanism O-ring ( if collapsed the engine will always run rich ) and wear on the needle jet , would suggest you check both and try again .
Luís
Luís
- UHR850
Re: Carb question.
ThanksLuisM wrote: ↑Tue Jul 25, 2023 10:55 am Hello Kees ,
Luís
- UHR850
Re: Carb question.
Well the hif38 didn't work properly so a Hs4 is now bolted on, fingers crossed.
Kees
Kees
