Adding Flash to Pass switch?
Posted: Sun Jan 08, 2023 2:56 am
by Terence
As per the subject..where is the best place to tie into the headlamp circuit? Dip dim switch?
My Headlamps are already running through relays that are powered by the lights switch, but I am thinking that I need to trigger the relay with a separate power line so the switch doesn’t need to be on to use the flash switch.
Do you use high beams or low?
Re: Adding Flash to Pass switch?
Posted: Sun Jan 08, 2023 10:34 am
by woodypup59
Main beam would be usual.
Posted: Sun Jan 08, 2023 4:36 pm
by Terence
woodypup59 wrote: ↑Sun Jan 08, 2023 10:34 am
So the main beams flash when the dipped beams are on or off?
Just trying to figure out how they supposed to function.
Posted: Sun Jan 08, 2023 4:48 pm
by Peter Laidler
You add an an ignition live into the new switch. New cable from switch to main beam wiring bullet connectors in wiring harness. Ignition on, flick the new switch and both main beams flash
Posted: Sun Jan 08, 2023 4:58 pm
by Terence
Peter Laidler wrote: ↑Sun Jan 08, 2023 4:48 pm
So I can tie into the main beam wire that comes out of the dip switch?
I have an auxiliary fuse panel that is ignition live that I will use for power.
Posted: Sun Jan 08, 2023 8:23 pm
by Peter Laidler
Yes, any main beam white/blue. That's a good idea to use the dip switch part of the loom
