As per the subject..where is the best place to tie into the headlamp circuit? Dip dim switch?
My Headlamps are already running through relays that are powered by the lights switch, but I am thinking that I need to trigger the relay with a separate power line so the switch doesn’t need to be on to use the flash switch.
Do you use high beams or low?
Adding Flash to Pass switch?
- woodypup59
- Has thanked: 8 times
- Been thanked: 22 times
Re: Adding Flash to Pass switch?
So the main beams flash when the dipped beams are on or off?
Just trying to figure out how they supposed to function.
- Has thanked: 135 times
- Been thanked: 113 times
You add an an ignition live into the new switch. New cable from switch to main beam wiring bullet connectors in wiring harness. Ignition on, flick the new switch and both main beams flash
So I can tie into the main beam wire that comes out of the dip switch?Peter Laidler wrote: ↑Sun Jan 08, 2023 4:48 pm You add an an ignition live into the new switch. New cable from switch to main beam wiring bullet connectors in wiring harness. Ignition on, flick the new switch and both main beams flash
I have an auxiliary fuse panel that is ignition live that I will use for power.
Yes, any main beam white/blue. That's a good idea to use the dip switch part of the loom
