1071 S engine
swifty
Been thanked: 29 times
1071 S engine
Post by swifty »
Regarding earlier posts about dating a 1071 engine . Note the open fuel pump hole ? ..Could the clever among you date this ? ….. Thanks Shirley
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
251 ENG
Re: 1071 S engine
Post by 251 ENG »
16th of may 1963
Does it have any numbers stamped on bearing caps ?
kit of bits
Been thanked: 18 times
Re: 1071 S engine
Post by kit of bits »
Did all FJ’s/ flat front blocks have an open fuel pump hole?
swifty
Re: 1071 S engine
Post by swifty »
Thanks Simon . My 1071S according to my heritage cert was built June 63 . So that all adds up nicely … . The 190 box has straight cut gears as well . …. i will have a look at the bearing caps .. shirley
Porsche 997 turbo S
I am from Essex
swifty
Re: 1071 S engine
Post by swifty »
Nothing stamped on the bearing caps . Also no stamped number on the block by the water pump hole ? . Is that what you expected re: the question. …. Shirley
Porsche 997 turbo S
I am from Essex
251 ENG
Re: 1071 S engine
Post by 251 ENG »
Yes probably, very early blocks have no stamped numbers at all , then you get some only on caps but we are talking about very early numbers such as C11
Alex
Re: 1071 S engine
Post by Alex »
kit of bits wrote: Thu Jan 05, 2023 7:35 pm Did all FJ’s/ flat front blocks have an open fuel pump hole?
I would guess (note, guess) that they did - the FJ cars had the dry-sump pump there I think.
richardACS
Has thanked: 41 times
Re: 1071 S engine
Post by richardACS »
swifty wrote: Thu Jan 05, 2023 6:27 pm Regarding earlier posts about dating a 1071 engine . Note the open fuel pump hole ? ..Could the clever among you date this ? ….. Thanks Shirley
Might you have a spare one of those? just the date I'm looking for :lol:
swifty
Re: 1071 S engine
Post by swifty »
That particular block belongs to my 1071 S but I have another two 1071 blocks so will have a look at the dates . …. Shirley
Porsche 997 turbo S
I am from Essex
Toby
Has thanked: 12 times
Re: 1071 S engine
Post by Toby »
Alex wrote: Fri Jan 06, 2023 4:56 pm
No they didn't. There are at least two types of FJ block. The one with the hole and a slightly later type without. My July 63 for example is an FJ but closed
1071 S
Re: 1071 S engine
Post by 1071 S »
Just to confuse things... my slightly later (F3A) block has both the flat front and the hole.... Can’t actually confirm the hole but does have the bolted on plate that would cover the hole???
Cheers, Ian
Toby
Re: 1071 S engine
Post by Toby »
Which date code is cast in the front on that?
1071 S
Re: 1071 S engine
Post by 1071 S »
Me???
F3A
Cheers, Ian
