96 Rover Mini Cooper - Rotor Arm
- Snoop
Hello - I have the above model Mini Cooper and I am looking to fit a set of new spark plugs leads, distributor cap and rotor arm as the existing parts are looking a bit shabby. I can't seem to find any info about fitting a new rotor arm in my manual - does this simply pull off and can be easily changed over or is it held on with a screw or small bolt?
Re: 96 Rover Mini Cooper - Rotor Arm
The rotor arm on a 1996 is just a push/pull fit. The distributor cap is bolted on, but you would have seen that already.
Dizzy cap is GDC156
Rotor arm is GRA2143
Dizzy cap is GDC156
- Snoop
