What throttle lever should I be using on twin H4s? I think the one I have is too short so the standard manifold bracket (http://www.minispares.com/product/Class ... o%20search )
points in the wrong direction?
https://sucarb.co.uk/levers-throttle-st ... evers.html
H4 throttle levers
- johnv
- Been thanked: 5 times
H4 throttle levers
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
- Ronnie
- Has thanked: 12 times
- Been thanked: 29 times
Re: H4 throttle levers
AUC 4454 (page 451) If you are using a works set up
https://mk1-performance-conversions.co. ... KD3509.pdf
But it will not work with that throttle stop bracket you linked to
