Replacement Hydrolastic pump connectors
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
My Hydrolastic pump connectors are a bit tired.
Does anybody know of any good sources for the bits?
Catmint
Been thanked: 15 times
Re: Replacement Hydrolastic pump connectors
Post by Catmint »
Hi Mark
The double ended threaded bit 21A1524? I am just about to make some stainless ones up either today or tomorrow, or minispares do a steel plated one
Gordon
rolesyboy
Post by rolesyboy »
Thanks Gordon. I meant the connectors on my Churchill pump (Dalek)
Interesting to hear you are making the double ended connector in stainless though. Send us a link if you do
Mark
There are loads on ebay, just not cheap.
https://www.ebay.co.uk/sch/i.html?_from ... r&_sacat=0
This may be a cheaper option, but you'd have to check it would be OK.
https://www.ebay.co.uk/itm/125344636165 ... HsQgAAAAAA
Has thanked: 135 times
Been thanked: 113 times
Yet ANOTHER masterstroke from Catmint. Making the double ended adaptor that connects the front hydro units to the pipes, from stainless.
You've only got to have a look at your originals to see how the 5mm (or it is 6) hole has corroded up to zilch to become the valve from hell!
GOOD move Catmint.
Catmint
Post by Catmint »
Peter Laidler wrote: Fri Oct 28, 2022 10:27 am Yet ANOTHER masterstroke from Catmint. Making the double ended adaptor that connects the front hydro units to the pipes, from stainless.
GOOD move Catmint.
rolesyboy
Post by rolesyboy »
mk1 wrote: Fri Oct 28, 2022 10:14 am This may be a cheaper option, but you'd have to check it would be OK.
Cheers Mark.
Decent price. Anybody know if these would work?
OGW 1082
Post by OGW 1082 »
Hello Mark,
I've used the the same ones you're enquiring about for years with no problems.
I buy them from SkyGeek in the USA ...about $30.00 US ...Schrader 556 High-pressure Strut Coupler.
Regards,
Glen
111Robin
Been thanked: 16 times
Post by 111Robin »
rolesyboy wrote: Fri Oct 28, 2022 11:08 am
Cheers Mark.
Seconded, I have one on my Churchill pump.
