Track day misfire .. what could it be?
johnv
Post by johnv »
Trackday yesterday, the car started to miss at the the very start of each session, not badly, maybe just one cylinder .. just for half a lap or so then it would clear up up and be fine for the rest of the session, no smoke as far as I know, temp and OP fine. Any ideas as to where to start looking? Thanks
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
atm92484
Re: Track day misfire .. what could it be?
Post by atm92484 »
Have you done a leakdown test?
I once had the same thing occur - turned out to be a head gasket that was on its way out. The extra heat from running under load would get it to reseal. Eventually it went but not after it lead me on a wild goose chase through everything else.
I've never had a bad coil start out bad then improve (always started ok then degraded as it got hot) but it is possible that it is the coil. Maybe airflow from the car moving at speed cools the coil enough that it starts working again?
GraemeC
Post by GraemeC »
We’re you sat ticking over for a while before the sessions? Could be a plug fouling up and then burning itself clear after a bit of time on track
johnv
Post by johnv »
GraemeC wrote: Sat Sep 10, 2022 7:07 pm We’re you sat ticking over for a while before the sessions? Could be a plug fouling up and then burning itself clear after a bit of time on track
Yes .. but its done a couple before this one .. starting off with Blyton . . and not had any issues
johnv
Post by johnv »
atm92484 wrote: Sat Sep 10, 2022 6:46 pm Have you done a leakdown test?
Haven't taken it off the trailer yet! What you say does make sense but I probably did 3 ir 4 sessions flat out after it started happening so I would have thought something bad would have happened if that was the case?
iain1967s
Post by iain1967s »
Plug lead insulation breaking down and arcing to the nearest metal part that it routes close to - grille, dipstick, alternator bracket etc. ?
Joel Welsh 4769VU
Post by Joel Welsh 4769VU »
Distributor cap cracked, loose?
Little moisture in it, then dried out.
Wauseon, Ohio- United States
Tartan red and black
I can't take credit for what others built- all I can do is try to put her back on the road. :shock:
You just can't fix stupid... you can hide it sometimes though... :lol:
atm92484
Post by atm92484 »
johnv wrote: Sat Sep 10, 2022 7:31 pm
Mine went on for a few sessions before going. Sometimes it was only first session of day and wouldn't do it until first session next morning. It definitely wasn't the usual head gasket failure.
Has thanked: 136 times
Been thanked: 115 times
I'm with Graeme C here. Start at the easiest and cheapest and correct upwards - or in money terms, downwards! Unless you have the high load facilities to test the plugs it's difficult to diagnose the actual 'problem' beyond the fact that it's broken down. But it's easy and cheap to replace the set and from then onwards it's a process of elimination knowing that at least it wasn't the plugs. Plug leads usually fail under load
johnv
Post by johnv »
atm92484 wrote: Sun Sep 11, 2022 3:08 pm
I'll try all the above then change the head gasket .. do you know why yours failed? I can't see that mine has any excuse to .. the car's never overheated, the head and block are freshy skimmed, BK450 hg, ARP studs etc , I'll be disappointed! Car starts and runs sweetly atm ..
Dan Tweed grey
Post by Dan Tweed grey »
Had this problem, put fresh spark plugs in and it sorted it.
trevorhp
Has thanked: 16 times
Post by trevorhp »
Had the same problem on a trackday and it was a poor connection on the coil.
Simple to check and cheap to fix
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
1 x chassis 007 1967 Cox GTM
