Joel Welsh 4769VU wrote: ↑Mon Sep 05, 2022 8:41 pm
,,,,, I'd post pictures of the crank taper- with a little bit of metal galling on it. I plan to polish it some, and lap the surfaces before going back together.
Question- would it be a wise idea to coat the taper with some anti-sieze compound before re-assembly?
The 'secret' I found to getting flywheels off is to fit them tight in the first place.
As you've found here, when they aren't on tight, they fret on the crank, then they are very hard to get off, often resulting in some damage to the crank taper.
I found the best way to get them on tight is to lap them together with a fine grinding paste. On some flywheels, I'll put them up in the lathe and the very end of the small end, I'll relieve as after they have been lapped a few times, they will get a step here that will stop the flywheel going on properly. I just turn that last 4 - 5 mm of the taper, parallel.
When it comes time to fit them on, I put a very light lick of 3-in-1 oil to the taper, then heave down on the bolt as hard as I can, it would be around 200 ft /lb. The Oil helps the flywheel slip down the taper, but then under the extreme pressure that developed, the oil film breaks down and they lock together on the taper. I wouldn't suggest using anything 'heavy' to lubricate here or there'll just be next to no locking occurring. It's the locking of the flywheel on that taper, and nothing else, that gets the drive from the Crank to the Clutch (and in to the Gearbox).
I do have a Hydraulic Puller for removing them, none of the screw types can make the power needed.
