998 Cooper Spark plug choice
- snoopy64
- Has thanked: 84 times
- Been thanked: 14 times
hi
is the NGK BP5ES the correct plug for a std Cooper 998? Champion N5 was original fit but not sure which is the best 'modern' equivalent...?
Kevin
Kevin
Re: 998 Cooper Spark plug choice
Champion N9Y (N9YC, N9YCC Copper Core versions) is a good alternative. It was used by BL in 998s and the Cooper S models.
- timmy201
- Been thanked: 38 times
N5 translates to a B6ES
Later on they went to the projected tip, noted by the “P” in the BP6ES. I’ve got some “unprojected” tip plugs to try but I haven’t had a chance to see them running yet. They are recommended by swiftune & KAD
In terms of heat range, 6 is a good place to start. 7 is a bit cooler for higher compression or boosted engines. 5 is a bit hotter, so it can help to burn oil if you have a worn engine
A colder plug will tend to foul easier and a hotter plug can cause irregular ignition events and run on if they stay really hot
- Exminiman
- Has thanked: 54 times
- Been thanked: 51 times
In the past would of gone for a Champion N9Y, we thought it was an upgrade to the earlier spec`d N5s.... but these days only consider NGK.
NGK seem more reliable and better choice of specs...I would go with Mark (BP6ES) on standardish car and go for a BP8ES (bit cooler) on anything likely to get a continued thrashing.
Amazes me how cheap plugs are these days even quite fancy ones - back in the day we seemed to spend, proportionately, much more, especially on two stroke bike plugs...
- tweedy998
Another vote for the NGK BP6ES here, always seem to work well on a standard(ish) car.
1965 Tweed Grey Mk1 Morris Cooper 998
- Has thanked: 7 times
- Been thanked: 6 times
yep, i have also these
MK1 Austin Cooper 998cc 1967 Smoke Grey
http://mk1-forum.net/viewtopic.php?f=6&t=26813
- snoopy64
Thanks everyone… with the variable quality of stuff these days it’s good to get a recommendation…
Kevin
Kevin
- Toby
- Has thanked: 12 times
- Been thanked: 5 times
The 1071 models used the N5 plugs until late 63surfblue63 wrote: ↑Fri Aug 12, 2022 5:14 pm Champion N9Y (N9YC, N9YCC Copper Core versions) is a good alternative. It was used by BL in 998s and the Cooper S models.
- Simon776
1071's initially used Champion UN12Y plugs up to engine number 28431.The 1071 models used the N5 plugs until late 63
Mine ran better on Champion N5 or N5C as they now are rather than the NGK alternative
Always ran mine on N5's with no problems either.whitewithblackroof wrote: ↑Thu Aug 18, 2022 1:46 pm Mine ran better on Champion N5 or N5C as they now are rather than the NGK alternative
