Hi,I have been asked to explain the function of the auxiliary relay of a works rally mini circa 67 68 . it affects headlamp flasher / 4 spot lights / headlight on high I believe,maybe more ?, but the order it all happens is unclear. This is a car with Riley Pathfinder headlamp flasher system, 1800 indicator arm without headlamp flasher. BTW, I have a spare Riley headlamp switch/assembly , for sale ?
Cheers Lindsay
works rally mini function of auxiliary relay
- Has thanked: 18 times
- Been thanked: 49 times
Re: works rally mini function of auxiliary relay
Mine takes a feed from the headlamp circuit - but I have different relays for the spots and fogs. I seem to recall the works cars had individual switches for each light btw?
