SU BURLEN PUMPS
big-un1967
SU BURLEN PUMPS
Post by big-un1967 »
Hi everyone
Q. Has anyone had issues with the “new” su pumps made by burlen?
I have had issues with 2 new ones on my a35 van (puller) and now on my 1071 (pusher).
All tanks are clean, and cars running on E5 with miller’s octane booster.
Cheers Paul
whistler
Has thanked: 18 times
Re: SU BURLEM PUMPS
Post by whistler »
Burlen.
Re: SU BURLEM PUMPS
What sort of problems ?
I’ve got one on HOY and all seems good so far
big-un1967
Re: SU BURLEM PUMPS
I have had 2 on my a35 just given up the ghost both brand new, and now on my 1071.
I have isolated the problem by changing the pump, and the issue goes away.
I’m just wondering if it’s the crap fuel out there causing it? As it goes off within a month?
P
Catmint
Been thanked: 15 times
Re: SU BURLEM PUMPS
Post by Catmint »
If you think it might be the fuel going off, try some of this stuff when you park up
https://www.briggsandstratton.com/eu/en ... l-fit.html
We have been well impressed with it so far
1071 S
Re: SU BURLEM PUMPS
Post by 1071 S »
I couldn’t get an electronically switched version to work properly so reverted to the classic point type which has provided stirling service..
Cheers, Ian
big-un1967
SU BURLEM PUMPS
Thanks all.
P
Herbert
Re: SU BURLEM PUMPS
Post by Herbert »
I've gone to the contactless type by minispares after two new ones failed within 10miles. Havnt had a problem since
Hipwell
Re: SU BURLEM PUMPS
Post by Hipwell »
Funnily enough had one pack up today, not sure how new it is but guess the last year or so. Just doesn't suck up fuel(Lines are clear, fuel in tank etc) Had it apart and can't see any issues, ordered new valves and sealing washers so will give that a try. Most of their pumps seem to be out of stock atm. Electrically seems fine. Other than that they seem fine, fitted plenty.
Re: SU BURLEM PUMPS
I have had about 3 or 4 brand new Burlen pumps fail over the last few years. I try to avoid them now.
Exminiman
Has thanked: 54 times
Been thanked: 51 times
Re: SU BURLEM PUMPS
Post by Exminiman »
Anyone know the pressure that the MS electronic pumps push out ?
Re: SU BURLEM PUMPS
Exminiman wrote: Fri Aug 12, 2022 5:37 pm Anyone know the pressure that the MS electronic pumps push out ?
About 2-3psi
Tech info for MiniSpares supplied pump here
https://www.hardi-automotive.com/wp-con ... B13312.pdf
Exminiman
Re: SU BURLEM PUMPS
Post by Exminiman »
Cheers for that, didn’t realise that they had a spec sheet.
PSI is well suited to SUs and Webers, got to be better that whacking an SU pump with a hammer, especially on a road car.
big-un1967
Re: SU BURLEN PUMPS
Seems I’m not the only one?
I have swapped the A35 over to a facet! Let’s now see 🤞
Cheers p
Re: SU BURLEN PUMPS
The facet one will still be going in 20 years time.
