buzzing sound from gear lever
Totally rebuilt gearbox and engine all new bushes bearing gears as far as I could find. all seems to work well apart from a slightly noisy drop gear although this is getting better the more I use it,and a buzz or rattle resonation on the long gear lever it goes away with a slight bit of pressure on the gear lever, any ideas what this might be?
- mab01uk
- Has thanked: 236 times
- Been thanked: 208 times
Re: buzzing sound from gear lever
Even the works Mini Coopers often had a remote gear lever complete with some rubber hose to stop the buzz.....
Sounds like the small bush that fits at the bottom of the lever could be worn.
Depending on the age of the shifter depends which you need, either part no 40 or part no 50 on the link
https://www.somerfordmini.co.uk/manual- ... earchanges
- Has thanked: 137 times
- Been thanked: 116 times
Mine buzzed like a box of angry wasps. As the others have said, changed the plastic bushes and it sort-of cured it. What I did do to finally cure it was to slim down the underside of the big split plastic washer thinggy so that it pressed down harder on the gearlever ball.
- mab01uk
When Minis were well used daily drivers changing the various bushes never worked for very long but there are some good ideas to try in this thread below:-
997 Cooper Gear lever is sizzling/vibrating:-
viewtopic.php?f=3&t=28592
- timmy201
- Been thanked: 38 times
I had a similar issue with my magic wand gear lever. I think the main issue is the ball on the end of the lever is metal in the metal shift cup. Later cars have the plastic bush
viewtopic.php?f=3&t=27897
I found some helpful ideas in the thread Mab posted above
Yes this is a magic wand type, interestingly i vaguely remember a Morris minor bush pushed onto the ball end…. When I got it back out of storage Now I know why!
