Eyeball fresh air vents dismantle
Robbie224
Post by Robbie224 »
Have a early 1971 1275GT it should have the chromed fresh air swivel direction vents.
In the past ones I have in mini have been hand painted a silver colour but no where near chrome but they are the rubber twist knob correct ones.
Does any one know if the eyeball assembly can be dismantled so I can get the directional vents out and chromed and refitted.
Re: Eyeball fresh air vents dismantle
66Traveller has done this successfully.
Robbie224
Post by Robbie224 »
Easy to dismantle once removed?
Niclas92
Post by Niclas92 »
I have done this with Innocenti air vents.
There is a ring, that holds the eyeball in place. This ring has some sort of "bajonett fittig", BUT it's also glued!
You need to break that glue away. I used a wide screwdriver to so this.
The glue is quite brittle and makes weird crunchy noises while doing this, but at least from my expierience the plastic wont break!
Robbie224
Post by Robbie224 »
Thanks. Sounds risky but I'll give it ago .
