which plugs - 8 port
pad4
Post by pad4 »
hey chaps - i need to put a set of plugs in the 8 port that will let me use it on the roads for a bit , the ones in there at the moment are a full on race plug and foul up easy, any suggestions which plugs to use
COOPERCO
Re: which plugs - 8 port
Post by COOPERCO »
Are they 10mm motorcycle types Paul??
If so we've used NGK C7E without too much bother. They are a lower heat range plug so warm up & burn clear very well. I would use a '6' if it were available but it starts & runs on the '7' & has been hillclimbed, track dayed & generaly buggered about with. The only fouling problems have been if the car is started & moved about in the garage without being fully warmed or driven. Four starts & stops on different days & then yes it will foul!!
In the garage with tourettes!
pad4
Post by pad4 »
thats exactly whats happnin, yes there 10 mm plugs and 8s i believe. and its just fouling with moving it about while i do a bit of work on it, lol my loverly 8 port sounds like a 3 cylinder diesel
LMM76C
Post by LMM76C »
Even Timo Makinen had to get advice from John Glover of Champion on that!
COOPERCO
Post by COOPERCO »
pad4 wrote:thats exactly whats happnin, yes there 10 mm plugs and 8s i believe. and its just fouling with moving it about while i do a bit of work on it, lol my loverly 8 port sounds like a 3 cylinder diesel
I think they are trying to tell us something.......'Drive Me' :lol:
