Tappet no 1
Robbie224
Tappet no 1
Post by Robbie224 »
Hi. Is it normal to have some side to side movement on tappet no 1. Adjusted tappets noticing once value no 1 is fully closed with tappet under no resistance load it can be moved side to side abit on the lubricantion shaft . Any thoughts?
Thanks Rob
Has thanked: 137 times
Been thanked: 116 times
Re: Tappet no 1
What we want to know is this;
does it move longitudinally - or slide - slightly left and right along the rocker shaft
OR does it twist or rotate slightly?
Robbie224
Re: Tappet no 1
Post by Robbie224 »
It slides slightly left and right along the rocker shaft, doesn't twist or rotate engine still runs well.
Re: Tappet no 1
Good......, that is simple end float. Just leave it alone
Robbie224
Re: Tappet no 1
Post by Robbie224 »
Thank you for the knowledge. Good to know now its there for a reason. .. what is the reason for a float end?
Re: Tappet no 1
Another name for end-float is 'running clearance'. It's as simple as that without going into the inner technicalities.....
Re: Tappet no 1
Usually there is a large flat spring washer fitted to either end of the rocker shaft to take up this end float. It is likely that someone has removed these at some time, leaving you with the situation you have here. The springs are not essential, but do help take up that extra bit of slop.
Item 34 in the above illustration.
Robbie224
Re: Tappet no 1
Post by Robbie224 »
1275GT rocker shaft assembly doesn't have any double coil spring washers does it?
Re: Tappet no 1
I thought that everything did. But don't have a GT Parts list to check specifically.
Robbie224
Re: Tappet no 1
Post by Robbie224 »
Hopefully this will help.
Re: Tappet no 1
12H engines do not have the spring washer.
Minispares sell two sizes of washer and a spacer kit so that you can correct any offset from the rocker to the valve stem
http://www.minispares.com/product/Class ... EG392.aspx?
http://www.minispares.com/product/Class ... EG169.aspx?
Robbie224
Re: Tappet no 1
Post by Robbie224 »
Perfect thank you. Is it possible to remove split pin from tappet no 1 end of shaft and slide that tappet off shaft with removing complete rocker assembly?
