Mk1 wiper wheel box sources
Terence
Post by Terence »
Are there any good quality replacements out there?
I replaced mine with some MiniSpares a few years ago, and they have failed with very little use.
I’ve tried two sets of new arms, both fit loose, so never installed.
Just looking for some alternative sources, that have worked for others. Thanks
Has thanked: 137 times
Been thanked: 116 times
Re: Mk1 wiper wheel box sources
Hi Terry, I've been doing some work on wheelboxes fro two of my pals round these parts restoring/rebuilding minis. It seems that the best idea is to find a set of wheelboxes with half decent splines. Leave them in warm oil for 12 hours and even the tightest spindles should release and rotate freely. You can ignore (?) the chattered 26 or 28 TPI threads on the ally shafts by machining new very slightly undersize hex nuts. That solves that problem. Rotate the toothed drive wheel so that the toothed cable is operating against good gear-teeth too. By doing this we saved 6 out of the 8 tatty old bits of crap wheelboxes they had to start with. Many heads made light work -= or in this case, made the wheelboxes work......
IslandBlue
Post by IslandBlue »
I'm guessing that the clicking/knocking noise that my wipers make is probably related to the wheelbox(es)?
Presumably having withdrawn the rack cable from the wheelbox tube the wheelboxes can be removed by loosening and removing the nut above the bezel on the scuttle? Tried this a while back but they were not for turning. Left some plus gas on them and then forgot about it until I had to use them on the way back from L2B :roll:
What you have encountered Island Blue is the start of the problem - so far as it seems with our recent experience (see above...) It's the dissimilar material and cheap alloy. We found that unscrewing the chrome 3/4" (?) nut is inclined to strip away some of the threaded sleeve, hence I suggested machining a couple of slightly UNDERSIZE nuts that will make best use of the remaining thread on the sleeve. It worked for us.
If the nuts have the slightest whiff of being tight then plenty of penetrating oil before you start is the order of the day. Like I said, between us we were able to save 6 of the 8 odd wheelboxes this way. Ironically, one of the tightest, that we couldn't save, was one that had been taken off a car 10 years before, nut replaced down the shaft - where it had just seized!
Annanuvverfing..... The shaft threads are 26 OR 28 TPI and when they are even slightly corroded, it's easy to mistake/miscount one from the other. Just check and double check before machining or fitting new nuts. Also, there are HEXAGONAL, 6 sided and OCTAGONAL, 8 sided nuts. So far as I can tell, the 6 or 8 sided nut is NOT indicative of the TPI
Thanks to 1071Bob for his help here too...
Nick W
Post by Nick W »
Works minis needed more robust wheelboxes, so they fitted them from a Bedford truck or similar vehicle.. these have a U shaped wheel in them that has a bigger mated surface area. You also have to change to a 150 wiper motor wheel to make up for the difference in wheelbox wheel size.
Up North in Sheffield
IslandBlue
Peter Laidler wrote: Tue May 24, 2022 9:36 am What you have encountered Island Blue is the start of the problem - so far as it seems with our recent experience (see above...) It's the dissimilar material and cheap alloy. We found that unscrewing the chrome 3/4" (?) nut is inclined to strip away some of the threaded sleeve, hence I suggested machining a couple of slightly UNDERSIZE nuts that will make best use of the remaining thread on the sleeve. It worked for us.
Thanks, will keep adding the penetrating oil and see where we end up!
Mini Spares make no mention of different thread count only hex or oct nuts, although the hex is Mk1 or Mk2 apparently? Not got mine to hand so can't comment on whether my June '69 car follows the "rules" :lol:
Terence
Post by Terence »
It’s the spline for the arm that seems so soft it just strips.
Toby
Has thanked: 12 times
Post by Toby »
Nick W wrote: Tue May 24, 2022 10:45 am Works minis needed more robust wheelboxes, so they fitted them from a Bedford truck or similar vehicle.. these have a U shaped wheel in them that has a bigger mated surface area. You also have to change to a 150 wiper motor wheel to make up for the difference in wheelbox wheel size.
The part number on those wheel boxes for the 150 sweep look like 72827?
Nick W
Post by Nick W »
Toby wrote: Thu May 26, 2022 9:58 am
It's the 72845A number that's for the wheel box complete
Nick W
Post by Nick W »
Nick W wrote: Thu May 26, 2022 10:08 am
look like 72827?
Toby
Post by Toby »
Not quite sure what your previous post was supposed to be Nick?
However here's a nice under bonnet shot clearly depicting the wiper motor marked as being 150
Nick W
Post by Nick W »
I was referring to the wiper spindle wheel box , I don't know the part number for the 150 wheel in the wiper motor..
They had to fit 150 sweep because of the larger wheelboxes
Nick
Stopped-again
Post by Stopped-again »
There’s a pair of Nos 72851 wheel boxes on eBay for £79.95, sorry haven’t a clue how to post a link.
Toby
Post by Toby »
The part number for the 150° gear is 748796
GraemeC
Post by GraemeC »
Terence wrote: Tue May 24, 2022 4:30 pm It’s the spline for the arm that seems so soft it just strips.
I think I would drill and tap the wiper arm to allow a small pointed grub screw to bite into the spindle.
Terence
Post by Terence »
GraemeC wrote: Thu May 26, 2022 2:27 pm
This seems to be the best solution, a couple of guys on FB pointed it out. I will give it a go.
Or couldn't you just get a couple of half decent wiper wheelboxes at Beaulieu and refurb them?
Terence
Post by Terence »
Peter Laidler wrote: Thu May 26, 2022 5:00 pm Or couldn't you just get a couple of half decent wiper wheelboxes at Beaulieu and refurb them?
Not an option… I live in Canada 🇨🇦
mrqcars
Post by mrqcars »
easy fix?
593FGU 62 997 MORRIS
888NLY 63 1071S MORRIS
DBC889C 64 1071S AUSTIN
LTG222D 1275S AUSTIN
LNG235E 1275S AUSTIN
M10KBT AUDI RS3 APR TUNED
F111XEM DUCATO RECOVERY TRUCK
