Brake Light Switch
111Robin
Been thanked: 17 times
Brake Light Switch
Post by 111Robin »
What are people using these days ?. Trying to avoid the poor quality "Lucas" rubbish from the usual places.
LarryLebel
Re: Brake Light Switch
Post by LarryLebel »
If you mean mean hydraulic switches used with silicon brake fluid, Harley Davidson switches seem to last longer.
111Robin
Post by 111Robin »
Yes hydraulic, with DOT4.
Herbert
Post by Herbert »
Does it make a difference if you use synthetic with a brake pressure switch ?
111Robin
Post by 111Robin »
No idea, I would doubt it.
NOS or good used ones Robin
Has thanked: 137 times
Been thanked: 116 times
Silicon fluid made absolutely no difference to my old Lucas switch on my 69 S. Still going strong
111Robin
Post by 111Robin »
Andrew1967 wrote: Sun May 22, 2022 5:40 pm NOS or good used ones Robin
Good used would do Andrew, let me know what you have, thanks.
I'll have a look and let you know Robin.
floormanager
Has thanked: 18 times
Post by floormanager »
Accel switches (for Harleys) are supposed to be good quality (not cheap)
https://www.ebay.co.uk/itm/272756949343 ... SwsCdhHmMH
https://www.amazon.co.uk/Accel-ACC-1811 ... B001OMKH7Y
111Robin
Post by 111Robin »
Thanks, I'll try a used one from Andrew, should be fine for now.
My friend who used to own a garage tells me if the inner diaphragm hasn't been punctured * then a good dose of air pressure can usually clear a stuck brake hydraulic switch. A rounded piece of plastic can also be used to carefull prod the diaphragm to activate the connection on the other sides. Flush out with brake fluid and try again.
* Usually punctured by the insertion of a screwdriver in an effort to 'clear-out' the blockage or obstruction.
