Does anyone know if the 1100 / 1300 clutch master cylinder is a different bore to the one fitted to the Mini.
I had a leaky clutch master cylinder after Blyton & when I came to re seal it this week, a normal repair kit wouldn't fit as the bore of the master cylinder I was re sealing was .7" where as the normal clutch master cylinder bore is .7 and a bit.
It was not an insurmountable problem as I could fit a set of .7" seals from a brake master cylinder & all is now fine, but I have been left wondering why this issue cropped up.
It is CERTAINLY a clutch cylinder, but is also certainly NOT a "normal" Mini one.
Any suggestions?
Clutch master cylinders
Re: Clutch master cylinders
Yes they are different. Mini was 3/4" (19mm), 1100 was 0.7" (18mm)
See page 1692 on this link. Beware this is a massive 2,700 page pdf so may take a while to load. I would advise that you do not try to open this if you are viewing on a phone.
https://irp-cdn.multiscreensite.com/948 ... LOUGES.pdf
- Been thanked: 9 times
Thanks Stu,
That explains that then
Thanks also for that brilliant download link. A really useful catalogue.
