Bench test a control box
gs.davies
Has thanked: 72 times
Been thanked: 68 times
Post by gs.davies »
Is it possible to bench test a control box?
Got a couple here and wanted to check they’re working before fitting them up or binning them…
floormanager
Has thanked: 20 times
Re: Bench test a control box
Post by floormanager »
Has thanked: 137 times
Been thanked: 116 times
That'd be interesting to know although there is a bit about them in the workshop manual.
gs.davies
Post by gs.davies »
As I thought, you do really need a generator and a battery in circuit..
Oh well 😂
For testing the regulator I would have thought you could use a DC Variable power supply in place of the dynamo.
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
Is there a reputable repairer in the UK of these Lucas Control Boxes ?
johnv
Post by johnv »
I cheated after a couple of Chinese non starters and got solid state internals fitted into the original box
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
gs.davies
Post by gs.davies »
johnv wrote: Fri Apr 29, 2022 8:58 am I cheated after a couple of Chinese non starters and got solid state internals fitted into the original box
That's interesting.. so a solid state control for a dynamo output? Got any further details on this?
johnv
Post by johnv »
gs.davies wrote: Fri Apr 29, 2022 9:01 am
http://www.dynamoregulatorconversions.com/contact.php
floormanager
I did my own for £70. Same unit as fitted in dynamo regulators.
http://dynamoregulator.com/ordering.html
Got fed up with rubbish modern ones not working. Had one of these for 7 years, run perfectly. Voltage is 14 volts without load.
I got my correctly dated regulator rebuilt by this company.
Ribblesdaleauto.co.uk
