Bolts ??
rogerotto66s
Bolts ??
Post by rogerotto66s »
I found these hefty bolts but have no idea where they go.
They are 3/8” wide and 16 threads per inch.
Any thoughts?
Roger Williams
Has thanked: 137 times
Been thanked: 116 times
Re: Bolts ??
Shorties look like they're UNC's and from the clutch slave cylinder.
Can't see the long ones going anywhere
1071bob
Been thanked: 52 times
Re: Bolts ??
Post by 1071bob »
Gearchange remote to diff housing.
rogerotto66s
Re: Bolts ??
I can account for the bolts for the shift housing and the slave cylinder.
My shift housing bolts look new so these must be the original bolts I removed 30 years ago!
Roger Williams
Re: Bolts ??
And while you're there Roger, don't forget to copper-slip / copper grease the shanks and threads where they pass through or thread into alloy
Re: Bolts ??
I can’t see those long set screws being used for anything on a Mini. They would be proper bolts if that length.
andy1071
Re: Bolts ??
Post by andy1071 »
I agree with Andrew.
And being pedantic... :roll: a "bolt" has a plain section of shank, whereas a "screw" is threaded up to the head
(strictly speaking, it's actually a "machine screw" to differentiate it from a "wood-screw"...)
Sorry... I'll get my coat... :oops:
winabbey
Has thanked: 5 times
Been thanked: 15 times
Re: Bolts ??
Post by winabbey »
Andrew1967 wrote: Thu Apr 28, 2022 10:43 am I can’t see those long set screws being used for anything on a Mini. They would be proper bolts if that length.
In Australia at least both long bolts and machine screws were used to attach the remote control extension to the diff housing. This is vouched for by John Smidt, the undisputed Mini King who has purchased, dismantled and repaired more Minis than I care to think about. It's one of his "I'll bet you didn't know" questions. Whether this is by design or due to supply problems is unclear.
The parts book quotes HZC628, which is a 3/8" x 3 1/2" zinc bolt.
wild_willy
Re: Bolts ??
Post by wild_willy »
I presume you have sorted your faulty indicators given you've now moved onto SU fuel pumps and newly discovered bolts. Sorry set screws.
Hipwell
Re: Bolts ??
Post by Hipwell »
The remote housing certainly had the long UNC set screws on mine.
Not many UNC applications on the Mini, remote housing, clutch slave and starter solenoid bracket mounting IIRC.
johnv
Re: Bolts ??
Post by johnv »
Hipwell wrote: Thu Apr 28, 2022 2:46 pm The remote housing certainly had the long UNC set screws on mine.
And ‘wok’ bolts
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
Re: Bolts ??
Possibly a supply thing then. We sometimes get set screws sent in place of bolts.
Personally I wouldn’t use set screws for that application and haven’t ever seen them myself on a car but quite obviously they were sometimes used.
1071bob
Re: Bolts ??
Post by 1071bob »
My '64 car has the same bolts fitted, that's how I recognized them in the original post. They won't be going back in though.
Re: Bolts ??
I've got long screws on mine after a quick look. I don't like it either but must have put them back during the many times I've had it all apart. Will change for bolts next opportunity. But that said, there is very little weight/load hanging on them to cause any concern - except that it ain't right! I wish I had all these examples of sound v non compliant engineering when I was teaching. REAL examples do keep lessons alive - and students awake!!!!!
