I’ve got to fit up the brake and fuel pipes underneath my car before I can get the subframes on.
How long should be left between the end of the pipe and the first bend going towards the front of the car? I can’t think of another way of working out how much to leave for the pigtail curl in the brake pipe at the subframe end.. I figure that if I get that first distance right it should work out ok at the other end..
Or is there a better way of doing this?
Gary.
Brake and fuel pipe measurements
- Has thanked: 19 times
Re: Brake and fuel pipe measurements
Gary, when I pop over I will bring along a set of pre-made pipes you can measure or copy.
Cheers. Mark
Cheers. Mark
- gs.davies
- Has thanked: 72 times
- Been thanked: 68 times
