Brake Line Leak
Brake Line Leak
Need assistance re: isolating and correcting a brake line leak.
This is the first time I am dealing with brakes during the restoration on ‘66 S.
Leak is coming from right front area where multiple connections reside.
As you know space is extremely tight for hands let alone tools.
What options might I have?
Roger Williams
Re: Brake Line Leak
Roger,
Have you got an NPT threaded brake light switch ?
There are parallel threaded switches .... that will leak. Been there, done that.
Re: Brake Line Leak
Thanks Andrew
The brake light switch, banjo bolt and 2-way 90-degree union are original to the car.
So I assume the threads match.
How can one access these joints to at least try to tighten?
What tools?
What needs to be removed?
Andrew1967 wrote: ↑Thu Mar 31, 2022 7:27 pm Have you got an NPT threaded brake light switch ?
What tools?
Roger Williams
Re: Brake Line Leak
The only thing I can think is a cranked (if standard spanner won't fit) spanner to get onto the bolt and hopefully can get access from under clutch housing .
Deep socket and wobble extensions to check brake light switch is tight.
Re: Brake Line Leak
Thanks Andrew
I will check available wrenches, sockets, etc
Roger Williams
Re: Brake Line Leak
Does anyone know the wrench/spanner size for the brake light switch and the banjo bolt?
Is their a reference anywhere for thread size and spanner size for various mini bolts?
Roger Williams
Re: Brake Line Leak
Hello Roger,
I get 1" AF for the brake light switch and 5/8 AF for the banjo bolt.
Regards,
Glen
Regards,
Glen
Re: Brake Line Leak
Thanks Glen
The largest socket I had was 15/16” and that was too small.
I will purchase/borrow a 1” deep socket to remove the brake switch.
I do have a 5/8” socket for the banjo bolt.
Roger Williams
Re: Brake Line Leak
Verify that both copper washers are in place. Number 15 and 17 in the picture. I have seen the bottom one accidently forgotten on a car.
Chris Miller
Chris Miller
- Has thanked: 137 times
- Been thanked: 116 times
Re: Brake Line Leak
I had a very small leak - weeping of fluid - from the switch part. Where the main steel body part is rolled over and sealed (or not in this case) the switch part. The brake light still worked but..... The small leak there allowed the fluid to run down to the sub frame. So with brake fluid all over the show, it made detection difficult. Luckily I had silicon fluid so no other problems
Re: Brake Line Leak
I have always wanted to try these ... this might be the time!surfblue63 wrote: ↑Fri Apr 01, 2022 11:44 am For tight spaces you might find crowfoot wrenches useful
Roger Williams
- Been thanked: 20 times
Re: Brake Line Leak
Brake flex hoses have NOT been replaced.
Roger Williams
Re: Brake Line Leak
New copper washers or anneal the original ones? I always anneal the new ones to!
Re: Brake Line Leak
Check the thread depth where the union goes into the flexy theres sometimes a different O/S to N/S the union can bottom out you will think it’s tight but it’s not..
There’s only about 2 threads different..
- Has thanked: 18 times
- Been thanked: 49 times
Re: Brake Line Leak
I posted on this somewhere, turned out that the recess in the brake pipe wasn't deep enough, as posted above. Had to replace the flexi pipe in the end.
Re: Brake Line Leak
I guess the first thing and due to access might not be easy is to try to ascertain exactly where the leak is coming from in that group of potential leak spots .
Maybe dry it all out with degreaser and then have someone carefully apply light pressure to the pedal whilst looking .
- Has thanked: 7 times
- Been thanked: 22 times
Re: Brake Line Leak
What Brake Pipes did you use?
I find that the new Braided front Brake hose from Goodridge are not identical.
One hole is deeper.
If you use the wrong hose, you are not able to turn part nr. 18 deep enough in so it will leak
One hole is deeper.
Re: Brake Line Leak
Upon closer inspection I found the brake light switch was not tight and the 2 copper washers were “not good”!
I disassembled all parts, cleaned then, replaced the washers and put all back together.
I used the original parts (flex hose, banjo, brake switch) so I do not anticipate any problems with compatibility.
I will bleed brakes this week and see if the leak was been fixed.
I used these wrenches/sockets on the various nuts
- 15/16” wrench on the bottom hose bolt
- 5/8” socket/wrench on the banjo bolt
- 1” deep socket on the brake light switch
A local hydraulics shop suggested using a “Dowty bonded washer” in place of the copper washer.
Does anyone have experience with these washers?
Roger Williams
