Gearbox 22A363
Minicooper1964
Gearbox 22A363
Post by Minicooper1964 »
Does anyone know if this gearbox will accept a std 1275 pre A+ Short engine ? i.e. will the crank clear the main gearbox web
Jason
Re: Gearbox 22A363
Post by Jason »
From memory a small amount of material needs removing to allow clearance for the web to pass. You should be able to see where if you fit the base case to the block.
251 ENG
Re: Gearbox 22A363
Post by 251 ENG »
Was this originally a 997 cooper gearbox case ?
Same stroke as a 1275 if yes .
I have a NOS case available if anyone wants one
Jason
Re: Gearbox 22A363
Post by Jason »
Originally fitted with cone synchro gear sets, in wand and remote version. Wand was 850cc and remote 997 cooper.
