Wheel studs for S brakes
dgear1984
Post by dgear1984 »
Hi,
Would anyone know if the genuine wheel studs for the s brakes have mowog on the end of them?
I’ve got a set of wheel studs from the drum setup and they have mowog but the ends are domed and run really close to the calliper on the S setup.
The repro wheel studs I have on my discs are so soft all the splines are worn and the studs start to slip.
Thanks Dave
Has thanked: 138 times
Been thanked: 116 times
Re: Wheel studs for S brakes
Interesting. There seems to be TWO types. A FLAT end and a slightly ROUNDED end. The flat ends have got MOWOG on them but not the slightly rounded ended ones
minibitz
Been thanked: 13 times
Post by minibitz »
Flat head studs are ideal but you should still have clearance with rounded head and S callipers.
Only clearance Issue I've experienced was rounded head studs used with aftermarket alloy callipers.
