Has anybody else had trouble getting the radiator hose
mounted on the water pump? I know I'm old and therefore
have lost some of my vigor but dish soap or some other
lub will usually do the trick. Not with this hose Both
are new.
I recently installed the same silicone hose on an evo pump and certainly struggled a bit but got it to work. Might be easier once the pump is mounted and you can work to get the hose in place.
